my first big build 3 15 sp4s on ampere 8.0 TFE 4th order blow through 06 avalanche
4CF01E09-278D-493D-A373-2A6105C1E207_zps i went through at least 150 screws ,while being in the most uncomfortable positions, and sweating like crazy!
put some weather stripping around the port hole.C6D9746C-6880-4D55-93C3-2412E8262163_zpsphoto bucket is lagging for some reason
that looks sick! can't wait to do mine! hows the the 4th order sound in there and if you don't mind PM me the specs. id be interested to see what ratio you went with and how much room this box takes up. i wanna leave 2-3 feet of my bed for stuff for beach trips or to move small stuff.
2002 chevy avalanche
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
Second set of T2652-s
D3100's
deadner
I'd bet it digs into the low 20 with ease, my sp4 loved the 4th I had for it
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
ok,this is were i need some help . got on the freeway and i finally seen my voltage drop to about 12v. then i backed off cause i smelled something electrical,i pulled over and checked the batteries,fuses,the amp was barely warm and so were the subs.got back on the highway and not even half way up,the 9k shutdown.went straight home and checked the ohms and this is what i got. the 9k came back on,thank goodness,but there is something wrong with my wiring,and i don't know what it is.
you won't have any room with this set up.the batteries and amp are an inch away from the back of the bed.but 2 18s in fourth order i believe would leave you a little more space.
