Mr Bigolsworth Posted September 1, 2014 Report Posted September 1, 2014 that looks sick! can't wait to do mine! hows the the 4th order sound in there and if you don't mind PM me the specs. id be interested to see what ratio you went with and how much room this box takes up. i wanna leave 2-3 feet of my bed for stuff for beach trips or to move small stuff.you won't have any room with this set up.the batteries and amp are an inch away from the back of the bed.but 2 18s in fourth order i believe would leave you a little more space.I could even do two 15's. What's your volume of each chamber? 2002 chevy avalanche Currently have: 2 dc xl 18 set of T2652-s scv-6k Ct sounds 75.4 270a mechman xp3000 d3400 Wanted: saz 200.4 Second set of T2652-s D3100's deadner
Karkov Posted September 1, 2014 Report Posted September 1, 2014 I forget what ohm your subs are http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=12#results 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
moredbs Posted September 1, 2014 Author Report Posted September 1, 2014 that looks sick! can't wait to do mine! hows the the 4th order sound in there and if you don't mind PM me the specs. id be interested to see what ratio you went with and how much room this box takes up. i wanna leave 2-3 feet of my bed for stuff for beach trips or to move small stuff.you won't have any room with this set up.the batteries and amp are an inch away from the back of the bed.but 2 18s in fourth order i believe would leave you a little more space.I could even do two 15's. What's your volume of each chamber? 2ft3 per chamber sealed,and 3ft. a piece for ported i believe.
moredbs Posted September 1, 2014 Author Report Posted September 1, 2014 I forget what ohm your subs are http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=12#results dual 1ohm
moredbs Posted September 1, 2014 Author Report Posted September 1, 2014 I forget what ohm your subs are http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=12#results dual 1ohm thats the same diagram i went off of.my head is spinning. i might just wire back up to 1.4 i didn't have any problems then.
moredbs Posted September 1, 2014 Author Report Posted September 1, 2014 should i disconnect the subs from the amp when checking the ohms?
Mr Bigolsworth Posted September 1, 2014 Report Posted September 1, 2014 I forget what ohm your subs are http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=12#results dual 1ohm thats the same diagram i went off of.my head is spinning. i might just wire back up to 1.4 i didn't have any problems then. wire to 1.4 and change your batteries and external reg to run 16.v to get that extra juice out of it. I'm thinking of doing 16v on a 7.5k for the two 18's and just doing a ported box at 16ft^3 tuned to 32hz so it plays well from 29hz to 55 really hard and doesn't drop below -1db all the way till 100hz. 2002 chevy avalanche Currently have: 2 dc xl 18 set of T2652-s scv-6k Ct sounds 75.4 270a mechman xp3000 d3400 Wanted: saz 200.4 Second set of T2652-s D3100's deadner
moredbs Posted September 1, 2014 Author Report Posted September 1, 2014 im not into the 16v, i don't have enough experience or knowledge for that. Anyway i was thinking i might have fried one of the voice coils.when i wired down i checked and got a .7 reading,now its at.4 I'm worried my dd1 was acting up when i set the gain,never got a solid red,just a blink,but the manual said this is normal. guess I'm going to open it back up and check each coil.
Mr Bigolsworth Posted September 1, 2014 Report Posted September 1, 2014 hope you don't have to recone so soon. fingers crossed its good. 2002 chevy avalanche Currently have: 2 dc xl 18 set of T2652-s scv-6k Ct sounds 75.4 270a mechman xp3000 d3400 Wanted: saz 200.4 Second set of T2652-s D3100's deadner
moredbs Posted September 1, 2014 Author Report Posted September 1, 2014 small update. checked wiring to the subs,and had to make some changes.went for a ride, and at .7 i had no voltage drop,or issues got louder too! I'm so happy it wasn't the coils!
