Roof down, found problem. How to fix?
just throw deadner over the spot after you cut it, as its a weak spot. it helps.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Its attached to some sort of free weight. About 5 inches l9ng. It moves around freely without those bolts. It cannot be removed without cutting into the roof more.
Was thinking of deadener behind it.bolt it back in and jb weld that seam with more deadener on top.
Whatcha think?
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Yea that free weight for w.e reason is bolted to that part 9f the roof that broke.
I just put some deadener behind it. All around the opening and shoved a bunch in there so I cant move up and down.
Its bolted back to the metal which is still attached on one side and deadener like crazy over top.
There has to be a reason for it so i didn't wanna remove it.
Setup:
Xs D3400/ Xs XP3000
