jakmagic Posted August 30, 2014 Report Posted August 30, 2014 Hey guys, a friend at work gave me this equalizer the other day. I have only found manuals for sale online and I really didn't want to buy the manual if I wasn't going to use the EQ. I have a Alpine cde HD149bt for a head unit which already has a 9 band EQ on it. I read somewhere it can be used as a crossover for a sub woofer if that's the only speaker its controlling? Also was wondering what the D.A.B control is all the way on the left of the device? 97 Buick LeSabre with stock 140 amp alternator XS Power D3400 (under the hood) using pdb distro blocks Big 3 done with 2/0 ga welding cable Alpine CDE-HD149BT head unit CT Sounds Meso 6.5" components CT Sounds 60.4 CT Sounds 1400.1 Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs) Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders) Connection BT2 & BT4 550 (Audison) RCA's Bunch of Mojo Mat
jakmagic Posted August 30, 2014 Author Report Posted August 30, 2014 97 Buick LeSabre with stock 140 amp alternator XS Power D3400 (under the hood) using pdb distro blocks Big 3 done with 2/0 ga welding cable Alpine CDE-HD149BT head unit CT Sounds Meso 6.5" components CT Sounds 60.4 CT Sounds 1400.1 Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs) Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders) Connection BT2 & BT4 550 (Audison) RCA's Bunch of Mojo Mat
jakmagic Posted August 30, 2014 Author Report Posted August 30, 2014 Sorry for the double post. Accidentally copied same link twice. Thanks in advance to anybody who takes the time to read or reply to this post. 97 Buick LeSabre with stock 140 amp alternator XS Power D3400 (under the hood) using pdb distro blocks Big 3 done with 2/0 ga welding cable Alpine CDE-HD149BT head unit CT Sounds Meso 6.5" components CT Sounds 60.4 CT Sounds 1400.1 Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs) Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders) Connection BT2 & BT4 550 (Audison) RCA's Bunch of Mojo Mat
jakmagic Posted August 30, 2014 Author Report Posted August 30, 2014 Another thing I thought of is how will this affect my input voltage to my amp? My head unit already has 4v per outs. Its does say on the back - output level 500 mv 97 Buick LeSabre with stock 140 amp alternator XS Power D3400 (under the hood) using pdb distro blocks Big 3 done with 2/0 ga welding cable Alpine CDE-HD149BT head unit CT Sounds Meso 6.5" components CT Sounds 60.4 CT Sounds 1400.1 Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs) Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders) Connection BT2 & BT4 550 (Audison) RCA's Bunch of Mojo Mat
TheMonolith2001 Posted September 8, 2014 Report Posted September 8, 2014 If the output level is that low I would make sure to check what the maximum input level it can accept is. 4v may be way too high. Also in the picture of the back of the unit where the wires are coming out, there is a red wire, a blue wire, and then....a blue wire trimmed to nothing? You may not even be able to hook this unit up without soldering a new lead for whatever that used to go to. Hopefully it is something you do not need. DAB is Dual Amp Balancer. It is a fancy way of saying fader. Turn it up and the rear volume is reduced, turn it down and the front volume is reduced.
