Help with a 4th order cut sheet
DatDude619
15s usually work in 1.25-2cbft sealed. A lot of people go 1.5 sealed, tuning the front chamber is gonna determine the cut off on the high end. The way to get the best output:wide bandwidth ratio is to find the sealed resonance of the sub in the amount of sealed airspace you want to run and then tune the front chamber to that frequency. Port area is also an important role, you wanna get the compression right. Also, the bigger the sealed side the lower the subs will play.
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Awesome any suggestions on a box for my particular setup?
RFsuggests tuned to 32hz Ported and I plan to invert the subs so I can smell coil if they heat up
Rf suggests 1.66 - 3.00 sealed and 2.66 for a ported
Walled and sealed c pillar is my ideal just not sure if that's too much box for the subs tho
  • Who's Online   0 Members, 0 Anonymous, 3202 Guests (See full list)
