martydmb Posted August 31, 2014 Report Posted August 31, 2014 So I was thinking of going to 14v system. I have a mechman 320amp alt and 3 d3100 and lowest drop is 12.5v on 2 saz-3500v2 each at .5ohm. The AH of the d1400 is 50 so I would go with 6 d1400s? Think the d3100 is 110 ah? Anyone know how much these batts weight? 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
Kyblack76 Posted August 31, 2014 Report Posted August 31, 2014 are you externally regulated? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
martydmb Posted August 31, 2014 Author Report Posted August 31, 2014 Pcm right now but mechman has a external regulator for my alt. Not internal. 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
martydmb Posted August 31, 2014 Author Report Posted August 31, 2014 Found the weight. 43.6lbs 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
