So this is my toy, a 2000 Jaguar XJ v8, this is the 3.2 version of the v8 so has around 240BHP if memory serves right
1559604_645395168858889_2852646541961113
10004027_647056722026067_834027845976075
Typical Jag - rich leather, propper wood and deep pile carpets
10151144_647056708692735_853406021686868
10259940_647056548692751_629464277600649
Only just fits in the garage
10168046_647203702011369_596755490866428
Yes this is a real place, always makes me giggle when i drive through it
10014977_651110344954038_355433912097402
So the plan with this car is a good SQ system, a few things will get in the way
-The Headunit is not a full 2din size and single DIN units look daft
-The boot is sealed from the cabin with a massive fuel tank
-My Mrs has said that it has to be tasteful and practical, no walls
So this is the plan
Leave the stock headunit inplace, the stock unit looks right in the dash and has tape/cd and radio
Mount a tablet where the centre vents are for MP3/FLAC playback though either a USB DAC or bluetooth
10502437_685609508170788_140695241495487
I did think about replacing the headunit with a tablet but it wont fit
10426167_685609534837452_341774516675760
Mount a small 10inch sub in the front footwell, the one i have chosen is a Ground Zero woofer
IMG_4384.JPG?m=1404681206
IMG_4387.JPG?m=1404681215
10406471_687806384617767_150072617339843
This will be run off an amplifier i already own, it will be run from an Audiosystem Twister F2>500 Class A/B amp, I own 2 of them - they were both installed in my old daily drive but the new install wont need them both
IMG_1346.jpg?m=1317602401
The front components and amp are still to be fully decided but i have an idea on what they will be
In order to make the tablet/stock headunit work i will be feeding all of it though a external procesor so it should look a bit like this
jag%20hifi%20plan.png?m=1404942841
Unfortunatly this is going to be a slow build as this is just a weekend car and im doing a massive build in my daily as well because i have just had to scrap my old daily boomer. Plus some of the cash i had put aside has had to be diverted to repairing bodywork
Yep a shelf fell off the wall damaging the wing and bonnet, its not too bad but it does need doing
1527004_705685079496564_4926762699925011
10616140_705685042829901_370089705334677
Why did you decide on doing the sub in the kick panel area?
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
The boot is pretty much perfectly sealed from the cabin due to the tank and it is that tall you cant hang anything off the rear shelf so it kind of rules out putting subs in the boot (Shame as i have a pair of DD 3510's doing nothing that would have been lovely)
This only left me a few options -
build an enclosure for shallow mount woofers on the rear shelf - would look odd
Under seat woofers - Not brilliant choice on the market
no subs - would work if i used massively powerfull mid-bass drivers but that would mean multiple drivers in the doorcards to get the level i want
Front mounted passenger footwell sub - this seems to be the best option
You cant really see it but the footwell goes back quite a big behind the dash so i have more than enough space to fit the sub box under the dash in that area, front mounting a sub like this is done more than you would think by SQ competitors over here in England so i know it does work if setup right
Tuned in. Sounds like interesting woofer placement
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
A pair of Ground Zero uranium components for the Jag
DSC_0186.JPG?m=1410205518
DSC_0187.JPG?m=1410205518
DSC_0188.JPG?m=1410205525
Very nice set of SQ speakers, just a shame that the mids will be hidden behind the OEM trim as they look a lot like dynaudio mids
So on with the front sub box, first step make up some cardboard templates
DSC_0191.JPG?m=1410205524
DSC_0192.JPG?m=1410205531
Now make wood panels from the templates, trim and adjust as needed - tack them together with hot glue to hold the shape
DSC_0193.JPG?m=1410205531
Check the woofer will fit in the box
DSC_0194.JPG?m=1410205537
Now the first coat of fibreglass, The reason for this is to fill gaps where the wood does not meet fully.
DSC_0196.JPG?m=1410205538
This looks a bit odd i will admit but i do have method behind the madness, when people usually make stealth boxes etc they tend to just fibreglass to the area and put a MDF front on it to hold the woofer, by doing it the way i have i will have more strength than just a straight fibreglass box.
That is all i got done today as it will need a few more layers of fibreglass, then put a front panel on it then trim panel
