timewarp Posted September 7, 2014 Report Posted September 7, 2014 Iam ordering a knukonceptz ofc 0 gauge dual amp kit . but from what i can tell i'd still need either a distro block and another inline fuse or a fused distro block . My mono amp has 0 gauge input and needs to be fused / My 4 channel amp has 4 gauge and is fused on the amp . For right now iam only running battery up front but will be changing the up front and adding one in back ( hopefull in a month ) I planned on running the 0 gauge then splitting into a 0 gauge and a 4 gauge out . Iam not sure if i should use a 0 gauge in distro block with a 0 and 4 gauge out and just add a inline anl on the 0 gauge out , and run the 4 gauge to the 4 channel amp ..... Or should i just get a fused distro block ? I looked at the ones on Knu but wasn't sure which i should get . Which way do i set this up , and if fused distro block , which one ?
deadbroke Posted September 9, 2014 Report Posted September 9, 2014 I would start looking at all the different distro blocks you can. I wouldn't get one that has 0 gauge for the input with a 0 gauge and 4 gauge output it's just sharing from the original run. I would look at multiple inputs unless you think your pushing enough electrical. Check out ebay or parts express
timewarp Posted September 10, 2014 Author Report Posted September 10, 2014 I got enough wire to do 2 runs of 1/0 now .
Skax Posted September 10, 2014 Report Posted September 10, 2014 Don't take my word on this but if your adding a back battery why getting a d block why not just run from back battery and fuse properly ? like I said im sure it would be fine just don't take my word 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
timewarp Posted September 10, 2014 Author Report Posted September 10, 2014 Don't take my word on this but if your adding a back battery why getting a d block why not just run from back battery and fuse properly ? like I said im sure it would be fine just don't take my word Your right but i dont have a back battery currently . Will be a month or two for that . Id like to get some sound in it now . I was going to make a post and debate getting either a higher output alt or since i want to upgrade battery under the hood , get one for under the hood and one for the back . My alt on my s10 is not the stock one but its 145 amp . Iam trying to see if i can go alittle bigger then the factory battery without alot of mods .
islandpride684 Posted September 10, 2014 Report Posted September 10, 2014 Iam ordering a knukonceptz ofc 0 gauge dual amp kit . but from what i can tell i'd still need either a distro block and another inline fuse or a fused distro block . My mono amp has 0 gauge input and needs to be fused / My 4 channel amp has 4 gauge and is fused on the amp . For right now iam only running battery up front but will be changing the up front and adding one in back ( hopefull in a month ) I planned on running the 0 gauge then splitting into a 0 gauge and a 4 gauge out . Iam not sure if i should use a 0 gauge in distro block with a 0 and 4 gauge out and just add a inline anl on the 0 gauge out , and run the 4 gauge to the 4 channel amp ..... Or should i just get a fused distro block ? I looked at the ones on Knu but wasn't sure which i should get . Which way do i set this up , and if fused distro block , which one ? http://www.amazon.com/KnuKonceptz-KNF-36-Gauge-Fused-Distribution/dp/B00F6K0YZ0/ref=sr_1_5?ie=UTF8&qid=1410392669&sr=8-5&keywords=fused+distribution+block+0+gauge 3 options you can do Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
