sbg Posted September 13, 2014 Report Posted September 13, 2014 So I am in no way a mechanic or know what most of the parts are on the motor. So I have a question, I drove home today and when I got into the drive way. I could here a slight knock sound from under the car. ( 2001 ford focus 2.0 split port) so I'm looking around and see a open hole in this part of the motor? Can some tell me what part and should the hole be plunged? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted September 13, 2014 Author Report Posted September 13, 2014 Car is running fine and don't seem to have a problem. But making a sound... 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
ProMaxx316 Posted September 13, 2014 Report Posted September 13, 2014 that's transmission and I think it's called a sight hole/peep hole. to see the flywheel/ring gear. If im thinking right. If there was a plug it most likely fell off. I don't think that will be the cause of the noise you are hearing. If it's worth building, it's worth over building.
sbg Posted September 13, 2014 Author Report Posted September 13, 2014 that's transmission and I think it's called a sight hole/peep hole. to see the flywheel/ring gear. If im thinking right. If there was a plug it most likely fell off. I don't think that will be the cause of the noise you are hearing. OK. I was thinking it was trans but not sure. Sound seems to be from the trans...could be vary wrong lol. Thank you . 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Jessica Posted September 13, 2014 Report Posted September 13, 2014 I was expecting to come in here and see a connecting rod sticking through the oil pan Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
sbg Posted September 13, 2014 Author Report Posted September 13, 2014 Ok after some searching on the web. And checking the trans fluid. Fluid is Burt and low. Started the car back up and the sound was gone. Looks like a trans flush is in need. Mod can lock thank you 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
