may i ask why??
shallows not only have a smaller mounting depth, but are designed to run in smaller enclosures as well. smallest recommended sealed for that driver is .4cuft these seem like a good match for your situation
JL and kicker shallow mounts would be similar, just check the specs some shallows require as much sealed volume as their traditional comparisons
-Drew
uhoh_45 said:
oh and did i mention elemntal design sucks ass
yep yep btw if you did not know you still need d4
DC.jpgDC POWER
run 4 in an clamshell ;-)
probably wont work under the seat but just a thought, 4 coils instead of 2 to distribute the power without needing a new box.
-Drew
p3 shallow mounts and keep the gain down.... u should be fine wit that if ur worried bout the power handling
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
the woofer can handle extra "clean" watts without much issue. if you keep the gains down and the power clean they should handle it. if you have the $ just drop on JL shallows ;-) 700rms 10" woofer with <6" mounting depth is tricky
-Drew
-Drew
yes i have found this out ...but thats why I was leaning towards the fosgates that I mentioned above ...I have not seen anything on the jl shallow mounts ...can you point me to some info
