dl9890 Posted September 17, 2014 Report Posted September 17, 2014 Would wiring 2 12" TS w3003 d4 subs to my kicker dx1000.1 work? The amp puts out 550 watts RMs X 1 @ 4ohms. just making sure i'm doing this correctly, thanks.
Guest Posted September 17, 2014 Report Posted September 17, 2014 since you cant wire that amp to 1 ohm, you have to wire at 4 ohms. which will give each sub like 250w our of the 600 they can handle up to. if you want to wire at 1 ohm you have to get a different amp, like a soundqubed 1200
SIDE SHOW Posted September 18, 2014 Report Posted September 18, 2014 either different amp, or second amp the same
dl9890 Posted September 19, 2014 Author Report Posted September 19, 2014 I'd just be better off getting different subs. Any suggestions?
SIDE SHOW Posted September 19, 2014 Report Posted September 19, 2014 Wire each sub to 2 ohm and run one sub per amp each sub will see 1000wrms, just get yourself a second dx1000.1.......... or just wire one sub to the amp. do you have your heart set on running both?
