2003 Bravada: 2 18's, AB, DD, XS, Singer
Damn them lights just set it off.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
Have been touching up details here and there with vinyl letting loose in spots, especially around the plexi. Little CA glue fixed that.
Those wondering about voltage, set gains with dd-1 of course and with it at max playing gain setting test tone, voltage at amp read 12.9v
I don't have a meter for that but looks like it should be safe. Got the OM-1 though.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Here is a quick system walk through video
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
some serious carpentry going on here man!
Yeah not too many square edges....a lot of router work. Glue smeared for 100% coverage. Even stuff that would not be seen has a "finished" look. The way it should be.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Gotta give credit to Ray Miller for doing the fabrication......I was more or less a handy helper having time constraints.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Well thanks....if I do I know I got one vote at least.....but I have a couple more things to do. Got a date with the termlab for one. Maybe do a couple videos.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Forgot about these guys. Because the led's created a 3/8" gap between back panel and box, these pucks were made to secure the panel to the box and prevent possible vibrations/slapping. Pucks were made from the same 1/8" hardboard, ca glue together, and Velcro strips.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
You can also see the led's duct taped in to prevent light from coming out the back side.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
that work is just so clean....and those night shots!!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
