Relyks Posted September 23, 2014 Report Posted September 23, 2014 2 - AudioQue 12" SD2.5 (12" Soundqubed HDS212) 1 - AudioQue 1200.1D (SoundQubed 1200.1) 1 - H/O Alternator 1/0 KnuKonceptz OFC Wiring kit I was gonna go Subs up port back around 34hz Any input would be appreciated also I cant remember the rule of thumb with the port walls and torres calculator. --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Guest Posted September 23, 2014 Report Posted September 23, 2014 L slot port is 3 common center port is 2 common 5 cubic feet 35-37hz after displacements 16sqin of port per cube.
Relyks Posted September 23, 2014 Author Report Posted September 23, 2014 why 5 cu.ft? @ 35-37 hz --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Guest Posted September 23, 2014 Report Posted September 23, 2014 why 5 cu.ft? @ 35-37 hz because thats what i've heard countless recommendations of.
Relyks Posted September 23, 2014 Author Report Posted September 23, 2014 Im confused i did 5 cu.ft on these 2 12" subs before so either I am not making the port right or that is just to much air for me. I dont even have that kind of room. --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Raptorman Posted September 23, 2014 Report Posted September 23, 2014 The HDC's will want the higher tuning and bigger box/port.The SDC's will do fine with the 32-34hz tuning.2-2.25 cubes net per.25-30sq in of port per woofer. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Relyks Posted September 23, 2014 Author Report Posted September 23, 2014 if someone could enlighten me on why 5cu.ft for 2 12" subs instead of the 2.8-3.0 cu.ft that is recommended. Box H13" x W25" x D22" = Net Volume of 2.88 Port H11.5" x W2.5" x L17" = 34hz port area 28.75" port area per foot 9.98" will this work? --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Guest Posted September 23, 2014 Report Posted September 23, 2014 how much space were you expecting to use?
Relyks Posted September 23, 2014 Author Report Posted September 23, 2014 The HDC's will want the higher tuning and bigger box/port. The SDC's will do fine with the 32-34hz tuning. 2-2.25 cubes net per. 25-30sq in of port per woofer. if someone could enlighten me on why 5cu.ft for 2 12" subs instead of the 2.8-3.0 cu.ft that is recommended. Box H13" x W25" x D22" = Net Volume of 2.88 Port H11.5" x W2.5" x L17" = 34hz port area 28.75" port area per foot 9.98" will this work? so this will work? nevermind per woofer.. --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Guest Posted September 23, 2014 Report Posted September 23, 2014 where did you hear 1.5 per woofer from?
