Hifonics Problems *sightnfrage*gegkzmitdzrat zav
Uriahia
There are so many good brands and so many bad brands steer away from the bad brands and you will have years of heavy use.
Also cannot have a versus thread comparing amps.
No perticular order for Good amps just off my head.
DC Audio. Rockford Fosgate. Crescendo.DD Audio.Populus. sundown what have I forgot help me here guys.
Your list is pretty concise.... but CT Sounds, Zapco, Directed....lol
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
I would recommend a Crescendo S1500.1, it will get you about 1850w @ 1OHM in dynamic mode and it's only $300.
Now you have my attention lol. I would also like to upgrade from the Hifonics and upon getting a second 15, I need around 2k RMS. Will this amp take a .5ohm load? $300 for a Crescendo with that kind of RMS is even better than the CT I was looking at....
I have heard it will, but I have no personal experience with it. They didn't take it that far in the dyno run on youtube.
http://www.stevemeadedesigns.com/board/topic/186209-crescendo-s15001-great-amp/
That's the Dyno run I seen. Very impressive power @1ohm, way over rated! That little amp packs one helll of a punch! If it is .5ohm stable, I would consider one of these for my two PB 3XL's.
I wish my final impedance could be 1 OHM on my HDS312's. I would have just bought a SoundQubed 2200.1D... that's what I really want. Too bad I'm limited to .5OHM or 2OHM. That would be a awesome amp for your subs.
If the amplifier is still under warranty, at least try to get it fixed so you can sell it to help pay for a better amplifier.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I just tried unhookin the RCA's and the Subs(the subs are wired correctly) its gotta be the the remote wire terminal on the amp if I unhook the remote wire its jumps out of protect then back into protect(tried it 3 times got same results)......... we hooked my brothers Hifonics Gladiator up it comes on with no problem.
My final impedance will be either 2 or .5 ohm once I get the second 15.... They're 2 ohm DVC subs. Like you say, a 1ohm load would be great but since that isn't happening, gotta try and find a nice 2k that is .5ohm stable.
Oh, you are in the same boat I'm in. Such a pain to find something in that range. I made a thread that is looking for a very similar amplifier.
http://www.stevemeadedesigns.com/board/topic/191797-looking-for-a-solid-2k-rms-amp-2ohms/#entry2866919
It is a serious pain! Almost worth adding two more 15's instead to get my load at 1.33. Didn't think of going with a 2ohm load though, I always was under the impression that amps were less efficient and got hotter @ 2ohms? Maybe I am mistaken....
  • Who's Online   0 Members, 0 Anonymous, 692 Guests (See full list)
