Uriahia Posted September 29, 2014 Report Posted September 29, 2014 I have a Brutus 2000.1D it won't even come out of protection mode after running it for 2 hours at 1ohm don't know why all wires are hooked up right and I have the big 3 and a good ground connection any input as to wwhy it would go into protection if everything else is okay? So now I need a new 2000watt 1ohm amp what's a good choice? I'm new to the group but not to car audio I just need some different view points on a new amp. Thanks in advance.
Jhunt94 Posted September 29, 2014 Report Posted September 29, 2014 Does that sub require a 2000 watt amp? 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Soccerballzs Posted September 29, 2014 Report Posted September 29, 2014 There are so many good brands and so many bad brands steer away from the bad brands and you will have years of heavy use. Also cannot have a versus thread comparing amps. No perticular order for Good amps just off my head. DC Audio. Rockford Fosgate. Crescendo.DD Audio.Populus. sundown what have I forgot help me here guys. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Uriahia Posted September 29, 2014 Author Report Posted September 29, 2014 I have 2 1000 watt nominal subs.
Jhunt94 Posted September 29, 2014 Report Posted September 29, 2014 The ones soccerballz mentioned are good choices. You could look at Soundqubed too. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
GassenD Posted September 29, 2014 Report Posted September 29, 2014 Had a Brutus 2k, wasnt bad, beat the shit.out of it, but after a month of use I decided to try a soundqubed 2200 and the quality was way better and more efficient. I've heard many stories on hifonics amps getting stuck in protect and never coming back out. '97 Explorer2 Sundown SA 15's SQ 2200D Kinetik KHC1800 (Front) Kinetik KHC 2000 (Back) KnuKonceptz 1/0 OFC 130A Alt + Big 3
Uriahia Posted September 29, 2014 Author Report Posted September 29, 2014 Just looked at a SoundQubed, Fosgate and a Digital Designs on EBay I'm liking what I'm seeing. I have rechecked all my grounds, sub wiring even my HU wiring their all good. I do hear a rattling sound when I move it but its still under warrenty.
REH Posted September 29, 2014 Report Posted September 29, 2014 Have you even tried to unhook the speaker wires and RCA's from it, leaving only the power/ground/remote and turning it on to see if you get the same result? You say you hooked it up at "1 ohm" for 2 hours, and now it won't leave protect... So you apparently did some changes to the system/new install and shortly after had issues. So it is quite possible that there are issues somewhere other than the amp itself. If you can't get it out of protect with unhooking everything from it, then it's screwed... but that would be the place to start.
AstoSoup Posted September 29, 2014 Report Posted September 29, 2014 I have the Brutus 1700.1D and while it couldn't do an actual 1700 RMS on it's best day, I have beat it to death and never had any issues. Try the troubleshooting section in this manual. http://www.maxxsonics.net/manuals/hifonics/pdfs/HifonicsBrutusBRZ2010AmplifierManual.pdf There is a way to connect the + and - briefly and that will sometimes bring the amp out of protect. I don't know the exact procedure off the top of my head so I don't want to give you wrong directions and fry your amp lol. Look at that manual though, the procedure is in there and will sometimes bring the amp out of protect. Try REH's method first, disconnecting one thing at a time, RCA's, speakers..... If it comes out of protect when one of these are unhooked, you either have the subs wired wrong, speaker wires have shorted or the RCA's have took a sh*t. Head Unit - Clarion VX709 7" DVD Touchscreen Mid/Highs - Front Doors - RF Prime 6.5" component mids. A. Pillars - RF Punch component tweets. B. Pillars - RF Prime component tweets. Rear Doors - RF Punch 5.25" mids. RF Punch 3-way passive X-overs. Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS. Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider. Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS. Box - 9.6 cu^3 net @35Hz, three 6" aero's. Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand) Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
RainStryke Posted September 29, 2014 Report Posted September 29, 2014 I would recommend a Crescendo S1500.1, it will get you about 1850w @ 1OHM in dynamic mode and it's only $300.
