Sub up, port side in a Blazer?
gckless
Has anyone ever tried it? If so, how is it compared to port back? Looking to do it because of space issues, port back won't work. Port would be passenger side, about 6" from side wall. Four 12's, probably two 8" ports, on 5k.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
My two options are sub up/port rear firing and sub up/port side firing. I can barely fit rear firing, would have to shave a couple cubic inches off of recommended for each sub (total about 9 cubes net, 10 cubes recommended), ports would be about 6" from the hatch. Side firing allow me to get adequate airspace for each sub and ports would be 6-10" from the side (depending on how I build it). I know sub up/port back is tried and true, but looking for input on side firing and if it would be better here.
Having slightly smaller volume than recommended isn't an issue especially if you are over powering your subs.. Back to your question, I think all setups are different so no1 can tell you whether it would sound better than having ports back. Its more of try and error. But I suggest you build the box and side fire the ports, then judge for your self.. What subs are you gonna use?
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
TRF Blacktops with SHD top assemblies.
Yeah, I know that's the best way. Just looking to see if anyone has done it before and compared the two. Might save me from having to build a big ass box.
I had 1-15 in a 4th order with port facing back doing ,148 at the dash...
I know port back is solid. Looking for info on port side.
  • Who's Online   0 Members, 0 Anonymous, 2505 Guests (See full list)
