9 cuft. box port size plz help
Ok so ive been reading alote.. was wondering if this is correct... i have a 9 cubic foot box. My port is 9"tall by 7" wide and 17" deep gives me just over 28hz... my question is, is my port to small.. to my understanding thats only 7 square inches of port area per cubic foot of box.... can anyone help....
Based on the amount of power you are using your port is probably sized OK. If you were to put a lot more power to those subs a larger port would probably be a good idea.
Builds:
use 3 6" aeros , should get way nastier even on that small amount of power ;)
Ok... i have another jl 1000/1 im getting ready to put in so they will be at rated power. Am i correct about my port being 7 square inches per cube... cuz i read somewere that i want 12-16 square inches of port per cubic foot of box
You are correct, 7 sq in per cubic foot. The whole 12-16 sq in per cubic foot is really just a rough guideline. Its better than nothing, but there are significantly better ways to determine how much port area you need based on the size of the subs, their xmax, tuning frequency, and power you will be using.
If you are going to be adding power, you will need more port area. Fecupe's suggestion of three 6" aeroports would be a good start, PVC actually makes a pretty good port if you put a nice flare on the ends. If you want to go with a slot port I would suggest you shoot for around 110 sq in.
Builds:
  • Who's Online   0 Members, 1 Anonymous, 6257 Guests (See full list)
