i need help on finishing touches on my box and any help would be appreciate
the box will have two SA-12s in it and 1inch thick all the way around
will try add pictures as soon as possible
the airspace for the sealed side is 1.041
and the airspace for the ported side is 3.317
if you need more information ill try my best to get is to you
Next time, use the IMG tags to embed the pics, makes it a little easier on our end viewing them.
Am I seeing that correctly, your sealed chamber is towards the front of your pics, ported to the back? What questions do you have? What is your tuning freq, and what are your goals with this bandpass?
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
yes the sealed chamber is to the front my tuning is at 32-35 i dont remeber exactly i was just wondering if that looked right to be a 3:1 ratio
">http://1zpqu4o.png
I'm no expert on 4th order bandpasses (that's my next project for the experience, have a spare sub to try it with) but everything I've read is that the ported section is tuned for higher notes. The net airspace of the sealed chamber dictates the low notes, ported section is typically tuned higher in the 40+ range. Somewhere around here there's a really good thread regarding 4th bandpass design.
Have you run these specs through WinISD or anything to have a look at what frequencies this thing will play at?
Build Thread
