i might change to port tune it to 40 but i might just go with this and see how it goes
Do you have a copy of WinISD pro to check this?
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
What's your clearance between the port and the back wall? Looks a little close from the pic.
Build Thread
it is a 4" clearance
I like to have a port width of clearance between the port entrace and the back wall. Being an inch short may not be the end of the world, but to hedge your bets I'd throw a roundover on both sides of that side of the port, inside and outside diameter (so that in cross section, the wood would look rounded and have no sharp edges.) It'll change your tuning slightly (bumping up the tuning on the ported side just a little most likely), but turbulent air don't sound good. You could also add some external port and short the internal port to gain some port clearance, but that will change your net airspace on the ported section.
Subs are going to displace into the sealed sections correct?
Build Thread
yes as of now the subs are going to be displaced in the sealed section unless it turns out not to work well that way i might go with a slight ext port and round off all the edges and also put in the 45s in atleast the back corners
Any time I see a slot/square port, roundover is my recomendation. That's what I do on all my enclosures.
Build Thread
Are you running 1 cu sealed for both 12s?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
I believe your sealed section should be at least 2 cubes.
oh lawd.
