Mids and highs amp help!!!
First lemme introduce myself.
Hey guys I'm Rob, been lurking around on forums a bit lately but haven't posted.
I drive a 2000 deville and just did a budget build in it.
Kicker mids/highs
Planet audio 1600.4
Power acoustic MOFO 15s
Orion hcca 5000 watt amp
It's in a 8 cube box ported around 32 hz
Ill post build photos soon
I'm having a problems with my mids and highs. I'll be listen to a song not even turned up half way and about 2 minutes into it my highs seem to fade away. Mids still there but highs and tweeters loose their punch. I still have stock tweeters plus a set of power acoustics maybe it's too much ohms on the amp with two tweeters plus the kicker 5.25 on each channel?? Help!! Highs should be so much louder!! When I first start the car up I can crank it and it screams to where it hurts my ears.
Kicker mids/highs
Planet audio 1600.4
Are the stock tweets connected to your mid/high amp?
2011 Chevy Malibu LT
Hertz SQL Setup
When I replaced my dash I did forget to hook up the pillar connectors but I quickly noticed there was no highs And reconnected them. I do have a couple sets of new tweeters I've wanted to install but wanted figure out the problems first.
Short answer no I haven't tried without stock tweeters
Parallel.
I was thinking that the stock tweets are 10 ohm. Plus a 8 ohm tweet and a 4 ohm mid.
But I think my power acoustic tweeters are 4 ohm so that would be less than 2 at the already weak/cheap amp.
  • Who's Online   1 Member, 0 Anonymous, 732 Guests (See full list)
