Just bought my first mono amp, I've been using 2/4 channels previously. I currently have 2 SVC 4ohm sub's, wiring them to 2ohms, they each have there own chamber with terminals, question is can I wire them with the terminals included? Or do I go directly to each sub?
Terminals on the enclosure? Yeah, why wouldn't you use them?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I was just wondering if I would get a better connection doing it direct to the sub (I'm kinda new to all of this)
Are you talking about wiring the amp to one terminal on the outside and wire the second terminal to the first terminal to get your 2 ohm load?
What amp are you using now?
Unless you're running a lot of power, and the wire from the terminals going inside the enclosure are like, 20ga, then don't worry about it.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I am using 12 gauge ATM but switching it to Knu 10 gauge, I'm running each sub at 450rms
Shouldn't be an issue. Just make sure the wiring on the inside is good.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Either way is fine and 12ga is fine for what you're running.
That works, i'd just be worried those wires are going to get pulled somewhere. I'd look into a way to tame them so they don't get snagged.
