I read somewhere on another forum before that someone made clear corners themselves by painting something on the inside of the lense. Does anyone know how to do this, what kind of paint to use, maybe the same topic I read awhile back on it?
  • 2 months later...
Some headlights can be separated.(2 pieces) After which you can typically pop out that orange lens makin your headlight corner clear. I will say though that the remaining orange bulb cast a orange glow(egg yoke) so you can 86 this by getting amber turn bulbs which, unlit appear chrome.Please recognize that not all headlight sealants will loosen up that easy and I believe that you wanna have grey sealant. Black sealant might mean you are s.o.l. What you do is put your housing on a cookie sheet real low temp like 200 degrees say. Bake checking every few.When you can actually separate the housing then you are ready to roll.Also drape a towel over the housing so you dont jack your housing up w pit marks.To reseal cook em press em and hold.This process also can eliminate moisture in your housing if that is an issue just cook an press in this case making a tighter seal.....
