monky69c Posted November 8, 2014 Report Posted November 8, 2014 Need a box design i have max dimensions 32W 14.5H 24D im going towards ported in middle powered with 1000 rms each sub.With recommended box specs
Aj11 Posted November 8, 2014 Report Posted November 8, 2014 vehicle, subs, amp, music you listen to... hows your electrical.... we need to know the subs to know port area. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
monky69c Posted November 8, 2014 Author Report Posted November 8, 2014 2013 hyundai genesis coupe 2 fi ssd 10s powered by hifonics brz2100 at 1 ohm stock electrical.yellow top battery ported box
Aj11 Posted November 9, 2014 Report Posted November 9, 2014 yif it was me i would do 3 cubes net with a single 6 inch port at. 3hz. they like bigger boxes. and fi is a great sub comp! i haVe nothing but great things to say about themk jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Joe X Posted November 9, 2014 Report Posted November 9, 2014 Here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 3 5/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
monky69c Posted November 9, 2014 Author Report Posted November 9, 2014 wow nice ill check it out ill built a dummy box first and if it works well will do thank you so much for your help
monky69c Posted November 9, 2014 Author Report Posted November 9, 2014 made the dummy box but it wont fit box is big kinda hard cause its to wide to fit in will a sealed box be good for them ssd 10s
Joe X Posted November 9, 2014 Report Posted November 9, 2014 Here is couple more suggestions see which you find suitable, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Option 1 (preferred): Option 2: Power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
