SMD 18" WinIsd File
Jay Bee
Hi guys.
I'm trying to use this software WinIsd but I keep getting the same error message over and over again.
(parameter error list) it says check consistency check on following parameter groups failed. See help file for recommended data entry procedure.
Does anyone have the WinIsd file that they could send to me or know anywhere online where I can download it from.
Thanks in advance
The in program help file lists the order in which the T/S parameters need to be entered. Let the program calculate as much as possible by entering the values in the order they are listed. WinISD will get grumpy if it's calculated values do not match the ones you're manually entering.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Here is the file for WinISD v. 0.7.0
https://dl.dropboxusercontent.com/u/1642665/Ascendant%20Audio%20SMD%2018_.wdr
Hope this helps. What philrab said definitely applies to entering in the info yourself.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 5316 Guests (See full list)
