Double Din W/GPS with features like the 80PRS
I currently own an 80PRS and like the features, I am currently running it active and want to run the same active setup with the new setup. I was curious if anyone knows if there is something comparable in a double din with GPS.
Thanks
01 Chevy Silverado X-cab
2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's.
2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp.
Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage.
96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time.
Pretty sure the nex 8000 from pioneer has active and TA
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
The new NEX line will do it.
Otherwise, Kenwood eXcelon units will have ALL the bells and whistles too. 3 way active, TA, great EQ, etc.
Be prepared to spend roughly $1000 on one if buying new.
  • Who's Online   0 Members, 0 Anonymous, 791 Guests (See full list)
