Kade Posted November 30, 2014 Report Posted November 30, 2014 Dealing with a planet audio vx3002. What are the pros and cons of running this amp (or any 2 channel amp) bridged vs 2 channels? 600x1 @ 4ohms 300x2 @ 2ohms 2009 Dodge Caliber SXT (Silver) Deck: Pioneer X3600BHS Amps: RF P1000X5 Front: RF P16-S Rear: RF P1694 Subs: 1 RF P3D2-10 Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire. Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
Triticum Agricolam Posted November 30, 2014 Report Posted November 30, 2014 There aren't really any pros or cons. When you bridge you basically are dividing your sub's impedance between the two channels, that's why you can wire to 2 ohms per channel individually but can only wire down to 4 ohms bridged. As far as your amp is concerned, it can't tell the difference between a 2 ohm load to each side, or a 4 ohm load bridged. The important thing is to not wire an amp to a lower impedance than it can handle. I have no experience with that particular amp, so I can't comment on how it will do specifically, but what I said above pretty much applies to any bridged amp. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
