dl9890 Posted November 30, 2014 Report Posted November 30, 2014 Could anyone build me an enclosure for a 2010 dodge avenger. The sub im using is a single 15" HDS3. It calls for 2.003 Cubic feet. Mounting depth 8.25". I'll be using a DX1000.1 on it. I've been looking at pre fab enclosures but they suck so i figured i'd have one built. Thanks for any help guys. Car specs: 31-32W / 17 1/2 H / 20 D
Joe X Posted November 30, 2014 Report Posted November 30, 2014 Here is a suggestion within your dimensions for a single HDS315 firing forward sealed off if possible, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
