rockFord_Expedition Posted December 11, 2014 Report Posted December 11, 2014 thanks for the replys , all my connections are soldered and heatshrinked , direct leads from the subs soldered to 8 gauge which goes straight to the amp . each sub reads 2 ohms . parrelleled at the amp to 1 ohm . is there a better way of checking things or am I best off just redoing all the wires and see if that fixes it ? I will check to see if the rca's are damaged at all , how can I check that the signal is coming through using my multimeter ? thanks guys You can check to see if there is any voltage present on them. When troubleshooting a system and trying to rule out the RCA's as the problem (this is only good to do if you KNOW the HU isn't the problem) what I like to do is: 1. Make sure system is off 2. Unplug all RCA's from all amps 3. Turn gain(s) all the way down on the amp(s) that you are going to test 4. Using a 3.5mm to RCA cable like this connect your phone/iPod/iPad/lap top to the amp using the cable and prepare (but don't play) a track with volume down 5. Turn your vehicle and your system on 6. Play a track. Gradually increase volume as needed to obtain a comfortable listening level If you do that and you have no problems, that tells you that the problem is in your signal, either from the source unit or the cables them selves Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Aj11 Posted December 14, 2014 Report Posted December 14, 2014 exactly^ that's the easiest way. i just enjoy running wires so i pull first. but That will save some time. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
chris j m Posted December 14, 2014 Author Report Posted December 14, 2014 few updates , I have ordered one of those rca things . I checked all the wires , no pinches or anything , good soldered connections. checked the rca's with a multimeter, I have re done the ground from the back battery plus added another solid ground to the chassis as well . heres the weird thing , I flicked the mode switch from single to master , and it works normally straight away . when I switch back to single mode the bass still wont play for at least ten minutes ? im starting to think somethings gone wrong with the amp . what do you guys think ? thanks
Hifonics Posted December 14, 2014 Report Posted December 14, 2014 Keep it on master and enjoy your bass? If you have a workaround that works, I say go with it. 2010 F150 FX4-18" AA Mayhem-Crescendo BC3500d-Pioneer GM-D9500F 4-channel-2 Crescendo FT1 -2 Crescendo Neo Forte 6.5 -Pioneer AVH-P3300BT-6000K HID Headlights/Fog lights-All LED interior lighting-20% tint on front windows, 1% rear windows, 5% windshield strip-Big3 (XSFlex 0ga) -DC Power 270XP -Group 65 NorthStar AGM battery Coming soon/plans: -Build log-Blacked out mirror reflectors-Tinted tails/3rd brake light
rockFord_Expedition Posted December 14, 2014 Report Posted December 14, 2014 Something is obviously wrong with your amp if flipping that switch fixes your problem. Do you have a buddy that has an amp you can drop in just for troubleshooting? Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
