Earthquake Ph10000w/d1
How much do they actually put out and how are they on power consumption?
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
LOL Damn Good Questions......
12 volts @ 2 ohm est.
2000 Watts Each
5000 Watts Strapped
16 Volts @ 2ohm est.
4000 Watts Each
8500 Watts Strapped
16 Volts @ 1 ohm burp only est.
5000 Watts Each
10,000 Watts Strapped
Those are only estimates. I'm sure someone has put them on the bench and tested them and probably came up below or above some of those numbers. As far as current draws at each rating I'm not sure.
Alright well I know Sean from Sound Solutionz had the PH5000 I believe and it puts out 2200 so thats respectable.
My graduation is May 29th and Sometime between now and then I will be getting a new amp.
You have two right?
-2.5% Tint
-2 18" DC LVL 4's
-Amps are undecided
You have two right?
I have two 10,000. Exact same amp as the 5,000 just that you can link the two together.
  • 1 month later...
