ssa icon
keith
Can anyone give me some numbers on what the icons can handle daily, I have 2 bdcp 1500s and want to take full advantage of both. I also was looking at the xcons but don't know if they would be ok with 2.20 net for each woofer, any help would be appreciated with this, cant seem to find just the right info.
http://store.soundsolutionsaudio.com/categories/sub-woofers/soundsolutionsaudio/icon.html
According to there site the icons can handle 1250 watts rms maybe take like 1300-1500 daily? this is just a guess. Because when I emailed PSI they said my woofer could handle about 1500 before I ran into problems. My subs rated at 1200 wrms. So I run it at 1100 watts. Also it says your amp does 1000 wrms @ I assume 4 ohms.
. Also you could email SSA and see if the xcons would work in 2.20 net.
BDCP im pretty sure will do more then 1000 @ 4ohms... and closer to 2000 @ 1..If you believe what the birth sheet says..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Mine put out about 1250 at 4 ohm but wanted to run at around 2 ohms per sub and that's around 1800 maybe better off with the xcons and different box. Do you know if their is any difference between sound quality of the to.
Honestly if it was me i would run 1 amp per sub...I have with other subs.. I dont know anything about those subs you have though.. i had strong electrical, and my aps were set with dd1.
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
  • Who's Online   0 Members, 0 Anonymous, 2362 Guests (See full list)
