07 Yukon battery question
If you reuse the factory terminal thing then yes, get a D4800 as it will be a direct bolt in application.
The factory terminal thing is a big metal and plastic bracket. Hard to explain but please go look at it for yourself.
If you cut your factory wires as to put them into aftermarket terminals mounted on an aftermarket battery then you can EASILY fit a D3400 or you can fit a D3100 but it is a VERY tight fit...BUT it has been done, just need to loosen the coolant tank to fit it in and it's a squeeze.
I have a 2007 Tahoe and bought the D4800. Used it for a bit, just chopped my wire and use a D3400. Then when I saw I could fit a D3100 I tried that as well.
I now use the D4800 but with aftermarket terminals.
This post is 100% accurate
Actually, I will find a pic. of the factory terminal thing so you can get an idea
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Here are some pics. off the internet. The two black brackets you see in the pic. I remove them every time I swap batteries, it just makes it easier.
GM-Chevrolet-Tahoe-12V-Automotive-Batter
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Yep I have already cut that off and I am currently using rockford terminals but will be happy to use skyhigh or anything. I dont have the cash now for another 3100 but how much better is a 3400 compared to a 4800 as far a system performance goes?
Good choice. 3400 is easy to fit and is an awesome battery IMO. By all means use the Rockford terminals, they are awesome man.
I didn't know you had already cut that thing off. =)
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
  • Who's Online   2 Members, 0 Anonymous, 923 Guests (See full list)
