i have a kenwood x-591 headunit for sale.
it supports almost everything (HD radio, satalite radio, bluetooth, etc)
it has usb input which is very handy :) i usally load my music up on a thumb drive and play from there. this also means no skipping at high db levels.
it will come with
-orginal box
-never used mounting sleeve
-the headunit and faceplate
-remote control
-the wires harness
-and a ipod cable
everything works as it should and is like new, no scratches on the faceplate. I just recently upgraded and dont need this anymore
this is the only pic i have but if there is any interest i will get more
heres a link to some pics and specs
http://www.sonicelectronix.com/pictures.php?id=8869 .................pics
http://www.sonicelectronix.com/item_8869_-...+KDC-X591.html# ..............specs
thanks
DC.jpgDC POWER
* CD/MP3/WMA Receiver with Remote and USB Interface
* Power Output:
o Peak: 50 watts x 4 channels
o RMS: 22 watts x 4 channels
* Built-in MOSFET amplifier
* Detachable, fold-down face
* 24-bit digital-to-analog converter
* System Q EX Sound Control (6 EQ curves and a 3-band parametric equalizer)
* "Supreme" audio processing for better sound from your compressed music files
* System E's+ high and low-pass filters
* Rear USB and auxiliary inputs
* Optional connecting cable gives you iPod control (uses both the USB and aux inputs)
* Compatible with Kenwood's Bluetooth® adapter KCA-BT100
* Compatible with Kenwood's iPod control adapter KCA-iP200 (USB or auxiliary input can be used for something else)
* Satellite radio-ready (XM or SIRIUS tuner, service subscription, and antenna required)
* HD Radio tuner ready (Requires KTC-HR100TR)
* CD changer controls
* Three sets of 4-volt preamp outputs
* Clock
* CD frequency response: 10-20,000 Hz
* CD signal-to-noise ratio: 105 dB
* FM sensitivity: 9.3 dBf
In-Dash Receiver Specifications:
* Receiver Size Single DIN
* Faceplate Security Detachable + Security Code
* Remote Control Yes
* Peak Power Output 50 watts x 4 channels
* RMS Power Output 22 watts x 4 channels
* Preamp RCA Outputs 3 Pairs (Front, Rear, and Subwoofer)
* Preamp Voltage 4 volts
* Built-In Equalizer System Q EX (3 Band Graphic Equalizer w/ 6 Presets)
* Display Color Multi-color
* Button Color Blue
* CD Signal-to-Noise 105 dB
* Warranty 2-year Sonic Electronix
* Sub Preamp RCA Output Yes
* Display Type Dot-Matrix Text Display
Playback Features:
* AM/FM Tuner Yes
* CD-R/RW Playback Yes
* MP3 Playback Yes
* DVD / Video Playback No
* FM Presets 18
* AM Presets 6
* WMA Playback Yes
Expandability Features:
* CD Changer Controls Yes
* Satellite Radio Ready SIRIUS or XM Satellite Radio Ready (SIRIUS SIR-KEN1 / Terk XMD1000 + XMDKEN100 Required)
* HD Radio Ready Yes (Kenwood KTC-HR100TR tuner required and sold separately)
* Bluetooth Ready Yes (Kenwood KCA-BT100 adapter required and sold separately)
* Memory Card Reader No
* iPod Ready Yes (Kenwood KCA-iP200 Required and Sold Separately)
* AUX Input Rear (3.5mm) + Optional Additional Rear
* USB Input Rear
Edited by Stephen_C
DC.jpgDC POWER
sold ^_^
DC.jpgDC POWER
This topic is now closed to further replies.
