load350z Posted April 4, 2015 Author Report Posted April 4, 2015 joe the man i was just about to pm! i wanted your input since i seen many builds you help other members with. but ok, with 3 6in ports that 84sq in of port area.. what would the tuning be? 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted April 4, 2015 Author Report Posted April 4, 2015 the enclosure i had in mind was 39in , 17inch tall, 17in deep which gives me 6.5cu net..minus the sub displacement .1/sub and bracing it should be right at 5cu.. correct me if i'm wrong 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
CleanSierra Posted April 4, 2015 Report Posted April 4, 2015 ^^^ Are those dimensions you gave internal or external? If they are external, your math is wrong Im not the one you want to try to troll. Just a fyi for you.
load350z Posted April 4, 2015 Author Report Posted April 4, 2015 external.. i just realized i didnt account for the .75 wood.. but feel free to correct me on what i did wrong.. im here to learn.. i can play with the depth about 3inches to give me volume if needed 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
CleanSierra Posted April 4, 2015 Report Posted April 4, 2015 I get 5.21 net before sub and port displacement. Im not the one you want to try to troll. Just a fyi for you.
load350z Posted April 5, 2015 Author Report Posted April 5, 2015 Can someone just tell me exactly what I need for aero ports as in length.. The more I play around with psp Inc calculator and 12 volt calculator the more I get confused! But here's a run down of what I'm trying to achieve: Eight 8s powered by a Incriminator audio 40.1 (3600w) tuned to 32-35hz Space I have to use is 39"wide 20"depth 18"tall.. can add more depth if needed! Subs displacement is .1/sub.. enclosure will be make out of .75 mdf.. bracing is also .75 mdf side to side, and front to back. Three 6inch diameter aero port is what I wanna use... If u need more info just ask please! 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted April 7, 2015 Author Report Posted April 7, 2015 Wrapping this post up... aero port dream wasn't happening so I went with a slot ported enclosure.. I'll post a pic later! 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted April 8, 2015 Author Report Posted April 8, 2015 What u guys think? Couldn't fit the port on the baffle do to limited space but the subs firing forward, port up. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
