Enclosure Recommendation
load350z
Any advice will help ... This is a trunk build. I posted the specs from the site but wanted to get other recommendations since the site recommendation is based on the 750 watts rms. I'm planning on feeding them around 7k-8k total daily.
Ported - 0.4-1.0 ft^3 tuned to 33-40hz.
T/S Parameters for HP PSI-8 ":
Revc = 1.5 or 3.0 ohms
Fms = 35 Hz
Qes = 1.1
Qms = 8.50
Qts = 1.0
Sd = 200 cm^2
Vas = 7.6 l
BL = 10.5
Mms =
Sensitivity = 76.5 1w/1m
Xmax = 48mm total (Yep)
Usable excursion = 2" total
Product Dimensions:
Overall diameter - 8.5"
Cutout Diameter - 7.25"
Mounting Depth - 5.5"
Displacement in enclosure - .06 ft^3
Weight - 16 lbs
2002 Nissan Altima v6 3.5
  • Four Incriminator Audio Death Penalty 15s
  • 5 Pairs DS18 Pro Audio X6.5BM
  • 3 Pairs DS18 Super Tweeters
  • Taramps TS2000x4 (Mids Amp)
  • Incriminator Audio 6.4 (Tweeter Amp)
  • Incriminator Audio 40.1 subs amp
  • Rockford Fosgate 3sixty.3
  • 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator
  • Big 3 zero gauge.
  • Excessive amperage H/O 225a
  • Alpine head unit
  • Lots of stinger deadener
Eight 8s
  • Big 3 zero gauge.
  • Alpine head unit
They seem to be confused about what Xmax is. Xmax is one way linear excursion. They have specs listed as 48MM "total" however "useable" excursion as 2". Those are the same thing essentially(48MM=1.9"). So my take on this wrote thing is that they are liars. What I believe you've got is a sub with 24MM of Xmax(one way linear excursion) and 48MM of peak to peak excursion(total throw).
Based on the T/S parameters, the sub is suited ONLY for ported applications. I'd do a box tuned to 35-38 Hz with about 160-180" if total port area(assuming 24MM of Xmax is a legit number). I'd also do this in about 5 cubes net. I have no idea how it would perform in the real world, but it would be a good starting point.
Btw, that's a LOT of port to try to squeeze into 5 cubes :(
Specs are funny, that's one of the reasons to not go with PSI subwoofers..
But if you are deadset on those, listen to Cleansierra's recommendation.
Modeling those subwoofers won't be easy since the T/S parameters will not be correct.
Well I have the subs already.. so yea I'm set on running them. 160 - 180 inches of port area is massive.i did talk to someone from them on fb and they recommend 5.5-6cuft total but nothing about the port area. thanks for the replies!
  • Big 3 zero gauge.
  • Alpine head unit
Just double checking. .. so the rule of thumb is out the window for these sub? Rule of thumb meaning.. 12-15sqin/cuft enclosure
  • Big 3 zero gauge.
  • Alpine head unit
For ALL the subwoofers, there is no rule a thumb, only a rule of dumb. :ph34r:
It's my belief that you certainly do NOT have a subwoofer that had 48MM of Xmax. I doubt that is even close to the TOTAL peak to peak number which would make them 24MM of ONE way linear excursion(the very definition of Xmax).
You have a mystery sub on your hands and would be best off having a professional use a DATS, Or IM-SG to find T/S specs(yes from D'Amore because it works at finding T/S specs).
Otherwise what you so is this: guess. Treat it like a similar 8" sub in its class(I'm not even sure how you'd determine what other sub it's like. Maybe the TC Sounds Epic 8" or the Sundown V2 or V3 8"? Those have like 16-18MM of Xmax which is a much more reasonable number for an 8" driver with not very much spider.
So, based on 16MM of Xmax subs a tuning of 35Hz, I come up with around 110-120" of total port area for the 8 subs in a common chamber box. That's not too bad and is definitely doable.
  • Who's Online   0 Members, 0 Anonymous, 3402 Guests (See full list)
