SQL50 Posted January 10, 2015 Report Posted January 10, 2015 Generally speaking, I most setups I see consist of like two dual 4 ohm subs wired to 1 ohm, two dual 2 ohm subs wired to 2 ohms. Pretty typical. Lets say I wanted to achieve a particular impedance, but ran an odd number of subs to where It's impossible to get that impedance. Here's the question, can you wire for example, two dual 4 subs and one dual 2 sub together for X impedance? Or does mixing voice coil impedances **** up the subs?
EP95 Posted January 10, 2015 Report Posted January 10, 2015 the subs with the lower impedance will receive more power no matter what the final load if my understanding of it is correct
islandpride684 Posted January 10, 2015 Report Posted January 10, 2015 just make sure your windows are up to get that hotbox effect and add some disco balls with some strobe lights... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
SQL50 Posted January 10, 2015 Author Report Posted January 10, 2015 Lol, I'll pass, thanks for the info.
