In need of an explanation
warhead052
As long as the port has enough area to keep port velocities at a reasonable level the shape of the port doesn't make a lot of difference.
The difference between aero ports, slot ports, octo ports, etc mainly comes down to their implementation. Performance wise they all get the job done.
Builds:
Well I punched in numbers into torres calculator and 4 4"x10.25" aeros will have 50.24" square inches of port area, but the tuning
frequency is 60hz. 2 4"x10.25" aeros have 25.12" square inches of port area. So smaller aero, even if there's more still means less port area.
You kinda lost me with your last post.
As you add more port area the port/s have to get longer to keep the tuning the same.
Builds:
Okay I plugged in some digits and this is what I came up with. Slightly bigger box but after the ports taking up space it has a much smaller net volume. If
I'm right that should mean it'll play a little louder and maybe move a bit more air. The slot port only has 4 more square inches of port area. Will I notice a loss or gain in sound quality and performance from that? Or should I just try the 4 4inch aeros?
I would increase the depth to 18. and your port 13.5 X 3.25 and 25inches long that will bring ur tuning to 34hz and 14.2 sq inches of port per foot and I would do 3 common walls
08 Ford F150
u got enter the number of common port walls and the displacement of the subs. which I roughly estimated the subs to be about .15 for both and I used 3 common port walls instead of the 2
08 Ford F150
well you could go back to your original 15x32x16 but do a port 13.5 x 3 and a length of 28. and if you want port in middle you use 2 common port walls or if you want port on side use 3
08 Ford F150
  • Who's Online   0 Members, 0 Anonymous, 893 Guests (See full list)
