Question on a 6th order
99blazer
I see a lot of people here trying out 6th orders around and I thought I would try my hand in one. This is a build just for fun and i wanted to get opinions on it. the sub is an old memphis audio. 15ms-104 and what i came up with on the sixth was 1.73 cubes on the back side with a port tuning of 34hz with 15.62 sq of port and on the front chamber 1 cube with a tuning of 55hz wtih 25sq of port. and it will only have about 100w going to it. does this look about right? any input is appreciated.
08 Ford F150
just a little ten. so like maybe shrinking it to like 12.5x1 and shortening the length to 15 would bring it down to 32hz
08 Ford F150
What are your port velocities for front and rear at 100 watts?
Builds:
Those are pretty low, which doesn't hurt anything. If you want to save some space though you could decrease the port area on both until they get to around 15-17 m/sec.
Builds:
I am going to start building this soon and I have a question about the chart. I have heard that some songs are recorded at like 0db to -5db correct me if I am wrong I am new to this build style. But my question is will it play these songs even though its showing its peak up around 4db. Like I said I am new to using this build style so any help is appreciated.
08 Ford F150
The graph in WinISD showing dB of gain, and the dB level songs are recorded at are two totally different things, you will be fine.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3006 Guests (See full list)
