xBridges Posted January 27, 2015 Report Share Posted January 27, 2015 Anyone have a box design I could use for 2 XL 12" subs? I have to build a box for a wood shop class I am in and don't want the box to be bad. I have some general knowledge about boxes and everything just need some specs to do off of. Thanks! Link to comment Share on other sites More sharing options...
Cj Kumz Posted January 27, 2015 Report Share Posted January 27, 2015 Need more info of your build. Like how much power you running, dimensions of your available space, type of music you listen to, type of car, etc. No 1 will suggest without proper info. Post those to start the ball rolling Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
xBridges Posted January 27, 2015 Author Report Share Posted January 27, 2015 running 2200.1 sound qubed amp. Listen to mostly rap or decafs music. going into a 2 door car. I would like the box to be around 5.5 to 6 cubes. Its going to replace the backseat and going to try a half wall type of style because the opening to my trunk is not very big and makes it difficult to get a bigger box in it. The car is a 2002 dodge stratus coupe Link to comment Share on other sites More sharing options...
BigManAC Posted January 27, 2015 Report Share Posted January 27, 2015 Man I wish I had that woodshop class in HS. Thats all I have to add. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw Link to comment Share on other sites More sharing options...
Cj Kumz Posted January 27, 2015 Report Share Posted January 27, 2015 Those subs require 1.5 cubes at rated power. Due to the underpowering a bigger box will be fine but probably around 2.5cubes per sub. Going any larger than 5 cubes for both might lead to very bad mechanical control and very boomy bass. So a 5 cube box tuned to around 33-35hz would work well in my opinion. Just set gains and subsonic properly Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
xBridges Posted January 27, 2015 Author Report Share Posted January 27, 2015 Do you have plans for a box? Link to comment Share on other sites More sharing options...
Cj Kumz Posted January 27, 2015 Report Share Posted January 27, 2015 Do you have plans for a box?If you post the dimensions you have to work with in the backseat I myt be able to come up with measurements Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
xBridges Posted January 27, 2015 Author Report Share Posted January 27, 2015 There is 45" wide 20" deep and about 28" tall to work with. Thanks! Link to comment Share on other sites More sharing options...
Cj Kumz Posted January 28, 2015 Report Share Posted January 28, 2015 My google sketchup is triping so I can't post a blueprint. But the dimensions I got for a 5 cube double baffled box @ 35hz is 20H x 44W x 18D for the external measures. Then slot port in the middle should be 5" wide and 18.5" tall, then physical port length is 23.5" deep.. I hope that can help without a sketch Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
vinny c Posted May 23, 2019 Report Share Posted May 23, 2019 looking at a uncommon box design..looking at either 4x12s or 4x15s. with slot port.i hav a toyota tazz hatchback..hav 2x deep cycle batteries aswell with 2xslabs..1x25k mono and 1x4ch amp..running with a sony usb deck..parametric..super tweeters and 6x9s in front doors...plz contact me via email on [email protected] thankz vinny Link to comment Share on other sites More sharing options...
