Jeep Cherokee WALL Rebuild, 6 12s 4th order 6 3800s
Have this posted over on CACO, but their build log section is rather dead. Looks like Im gonna be spending some more time on here :) First build in this Jeep was 8 SA 12s on 2 Ampere 3800s, then 4 3800s, then 8 Zv3 12s. Nowall. Was doing 57s+ sealed peaking at 36 and on music and a 54~ @ 28hz so very musical. Had some freak voltage spike one day in the rain and it took out my volt meter and 2 3800s. I got upset and pulled everything out, sold all my old batts and decided to rebuild. This time go big, and wall it.
New plan is 6 custom Zv4 12s on 6 Ampere 3800s on 14 D1400s. I have added a 3rd alt, a Chevy Ad244 160A to run the car, and my other 2 Singer 270 hairpins will be charging the D1400s. The zv4s are built with SPL cones/surrounds, SPL spiders and NSv2 coils. Their t/s specs are closer to that of NSv2 12s because of this.
Subs! :)
13085_10154891649875720_5806206608180437
10806348_10154891649945720_3887102905011
10678832_10154891650395720_1638831779025
Heres where I'm at.
10420188_10154769559940720_2300148829149
1939993_10154700000775720_58226169299684
Had to plate the b-pillars because they were splitting. Passenger side in particular was almost broken completely through..
10417020_10154700001325720_5164317509250
1530491_10154700001820720_61098548702303
1510353_10154740415790720_75234133853931
Old roof.. another reason I pulled everything out. It was ripped in NUMEROUS places and leaking BAD.
10639557_10154740415985720_3540785149043
1506437_10154740416100720_15447541414345
10436164_10154756999080720_7246232529808
64736_10154756999410720_5899960635025642
10305180_10154765532655720_7927257731962
10641096_10154765533080720_7568884878555
10639517_10154765533375720_2603331720201
1555305_10154780230045720_73926855433410
10653707_10154782190095720_4113749079825
Custom rad hose to go around new alt
10301280_10154783185440720_6628958687591
10629557_10154798695170720_7454726507690
Roof!
Awesome so far
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
10881931_10154924464240720_7362569265885
9 sheets of Arauco cabinet grade plywood
10868283_10154924464600720_2630794059135
Gluing and screwing together sheets to double them up
10849753_10154924464700720_6259501611209
4 layer baffle
10881650_10154928457655720_4951781622527
Glued and screwed together and doubled up dividers/braces added for sealed section
10885360_10154928457760720_4375355944464
Back, bottom and side screwed together. Baffle just sitting there for now.
1484542_10154932850285720_19927833929365
Bolts welded to pieces of metal and stuck through box for studs.
10806248_10154932850380720_2580831097185
10885161_10154932850495720_3686069639061
Took what felt like all day but all studs mounted and holes drilled for subs
10443421_10154948084045720_5781936475967
10897032_10154955110155720_7032216144035
10896938_10154955110285720_3521404767932
10888571_10154955109755720_8014576072883
Miters arent perfect but its more than good enough for testing when the time comes. I was later told by Jared (think JEEF) that flat wall 4ths tend to load better with a tall rectangle port, not a square... so may swap to that later depending on how this does.
Spent like 3 hours today doing body filler in parts of the box and sanding. Mostly because the braces I made for the ported section I welded up inside the box, and the splatter burned into the wood a little and made tiny little pits.. oops. They should be fixed now, and I have a little more sanding to do and it should be ready for paint and maybe caulk beforehand in the seams where I cant sand very well.
Wow this looks like a great build with alot of quality time put in, nice work man! Can't wait to see it up and playing :good:
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Been following the build on caco, nice to see you over here. Look forward to the results :yahoo:
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
