moredbs Posted February 23, 2015 Report Posted February 23, 2015 Or strap 2amps at 2ohms,and each will actually see a 1ohm load.
gage120 Posted February 23, 2015 Author Report Posted February 23, 2015 So if I got another one of the amps I have now would that be a bad choice
Deeznutz Posted February 23, 2015 Report Posted February 23, 2015 You're going to have to do alot of research on this site. You're too focused on the watts, thinking that's the end all. I am running an old school Lanzar Optidrive 50C 767W @ 0.5Ohm, pushing 2 I.D. IDQ-12V2D2 in a 2.5cf ported box,and at a mere 767W, they are pretty freakin' loud. It's not about the watts, because 2000W calls for alot of current, you're going to be opening a big can of worms if you amp for 2000W. Research the system as a whole, not just the watts number. -Frank
Deeznutz Posted February 23, 2015 Report Posted February 23, 2015 Here is the can of worms part. You jump into more $$ when you try to go bigger. Rule of thumb, 8g 500W 4g 1000W 1/0g +1500W 2 subs 500W a piece would do the job too you know. Because true 1/0 gauge will set you back about $75-$95 to do it right. You can stay at true 4 gauge with 1000W amp. -Frank
