Remmember electricity is the same as water traveling through a pipe.
What you put in will not have the same amount of force (current) after it travels so far.
So with the line driver at the amp, if it recieves a crappy signal at the end it will amplify a crappy signal.
VS being at the starting piont and applying more force to push the signal to the amp.
I just have a crappy set of circumstances to deal with.
Thats why I was wondering how bad it would be to mount it near the amp.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
