I just got a Phoenix Gold TLD22 line driver.
They recommend mounting it as close to the head unit as possibble.
In my truck that might not be feasable.
Whats the conciquences of mounting it at the amp I want to use it with?
The length of the RCAs are 9 feet to the amp I want to use it with.
Also there is no way to mount this thing unless I pull out the circuit board and drill holes in the bottom of the casing.(No mounting feet)WEIRD.LOL
opinions please
And I think it might be to heavy for velcro. unless I can mount it just rite.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Come on guys, there are enough people online right now that theres gotta be someone that can help me.
Id just get some 3M double sided sticky tape and use that to stick it up someplace.
Otherwise if your stashing it in your dash someplace, zip tie it to something.
I dont know if the Phoenix Golds are totally different, but Im guessing it does not have adjustable voltage for the output on it, that is maybe why its said to be used as close to the radio as possible because by the time the voltage is passed through the rca cords it will be a little weaker in signal strenth, where as if it was used close to your amp.
That is just my guess since I couldnt find to much info on it, but I didnt see anything about it having adjustable voltage.
My old audiocontrol line drive that I was messing with got mounted right by my amp, and connected with a 1 foot rca cable, but then again i was able to adjust the output voltage on it.
It is adjustable up to 8 volts I only need 6 volts. The sensitivity controls are under the cover.
Rite now I've fot 1 volt on an amp that can handle 6 volts RMS.
if its adjustable I really dont see the big deal of why it says it has to be mounted as near the headunit as possible, but if thats what the instructions say, you should probolly do it for best results ;)
(Fabrication)Yep I guess thats why we do car audio ya need to beable to fabricate or find a new hobby.LOL
yeh the audiocontol overdrive's manual says it's suppose to be mounted near the HU also. just run a 3 ft cable from the HU to line driver and RCA's from the line driver to amp(s)
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
no no no!! no finding a new hobby....
This hobby makes me go broke and puts a smile on my face doing so :mad:
LOL :D
probolly does. I have no idea what happened to my manual :mad:
The only other reason I can see for this is because you will have the cleanest and strongest voltage the closer you are to the headunit.
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
