Image dynamics new 12" v4
I am building a custom box for this sub. Was wanting verification on my measurements. I have done the math, and using the manufacturer specs have come up with that the box need so be 22"x22"x10" ID with a 10"x1.5"x16.77" slot port. If anyone has a better design or can confirm please let me know. Thanks in advance.
What series of sub, what amp and what vehicle would be necessary to know to see if your box is ok.
So here is a suggestion for the sedan, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Thanks joe X. I have worked both figures. Your design and mine is within 2cuin of each other. I will go with your design as long as I can get it to fit through the trunk opening. I might be able to lay the seats down and push it through the front though. Thanks again for the input.
I had a couple of issues with your suggested dimensions, one needed to fire the sub up which is a no go with trunk cars, secondly various issues with your port, area, height and internal end clearance, so I submitted the above to you, if you have any issues with the dimensions I can fix them for you or help you to do your own if needed.
  • Who's Online   0 Members, 0 Anonymous, 4888 Guests (See full list)
