**Toyota Tacoma 2 ZV4 15s 7k build**
Got the toolbox sat back in place finally
cut a piece of diamond plate to hide and clean up the battery rack
IMG_20150218_162613543_HDR_zpsztcld3cp.j
loganberry, on 17 October 2009 - 11:39 PM, said:
on the lows it sounds like a 90 year old vagina flapping in the wind
JayP, on 10 June 2010 - 4:53 AM, said:
Your truck looks like a prostitute gave the car a blow job with starburst in it's mouth.
got more done on the box...
Screenshot_2015-01-28-10-06-37_zpspuktpy
bottom of the port pieces mocked up.
top piece of the port...
Screenshot_2015-01-27-19-38-36_zps1yuw1n
first layer of stain on the box...
top port piece stained
Screenshot_2015-01-29-19-11-13_zpsnzbcfp
inside and sides stained and polyurethaned, plexi windows cut, t nuts put in. getting closer
bottom port piece stained and polyurethaned
reinforcing the sonotube ports, ended up wrapping them in deadener, resining the inside of the tubes, and wrapping them in vinyl...
Close up on the top edges of the box
close up on the kerfed part of the box
Leds mounted in and full shot of the inside of the box!!
ports wrapped and painted!
Box is wrapped!!! finally coming together :)
bolted a piece of 1/2" birch to the back wall, we also put deadener on the wood to stop any rattling from the box being lag bolted through the 1/2" birch and into the sheet metal on the back wall.
building up the base now. the box will be screwed into the flat piece on top of the base and the base will be bolted to the truck.
IMG_20150201_131657387_HDR_zpsscuks1ta.j
IMG_20150201_135819621_HDR_zpswgdnerfw.j
there were not many pics of building the tool box because we were in such a hurry... but its almost done!! toolbox will also have leds inside of it.
Box specs? Looks awesome
Box is 8.6 cubic foot net after all displacements, tuned to 32 with 10 sqin of port per cube...
Box is in, bolted down, base is wrapped, stained and polyurethaned!!!
