07SRT-8 Posted March 4, 2015 Report Posted March 4, 2015 Hello - I am new to the site as a member. I am in need of a ported enclosure design for my 2007 Charger SRT-8. I will gladly pay for the time and knowledge that comes with supplying a plan. Below is a list of my equipment and space limitations. Thank you in advance for taking the time to help out a new guy. 2 Sundown Sa 12s Dual 4ohm Wired to 1ohm Hifonics BRX 2000.1D Pioneer AVH-2700BS Head Unit Available Dimensions: 32" Width 15.5" Height 20" Depth (This is a preference. This will allow the trunk false bottom to still lift up and access my battery. That is also where I have my amp rack. I am open to this changing if needed for a better enclosure. Performance of the subs is my #1 priority) I listen to all types of music but particularly Rap, Hip Hop & R&B Thank you again for any help anyone can provide
Joe X Posted March 4, 2015 Report Posted March 4, 2015 So here is a couple of suggestions, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4", figures are just assembly guides:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. 1) This is a little larger but other than that better overall: 2) This is the smaller one (by a bit only) it should still work fine and let you (maybe) access your stuff.
REH Posted March 4, 2015 Report Posted March 4, 2015 Joe can I ask what you use to come up with the designs and cut sheets laid out that way?
07SRT-8 Posted March 5, 2015 Author Report Posted March 5, 2015 Thank you so much Joe!! That will work perfectly!!!
