Box shaking
Cj Kumz
Hey people I was in my mates car yesterday and noticed his bass just didn't sound right. So when I had a look I noticed his enclosure shakes a lot as the subs are playing. He is coming over the weekend so we can diagnose his issue. What could be causing this? And what are the key things I should look for when examining??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Cheap material, box not being braced, not being bolted down.
Just look at the over all build quality of the box. Make sure its strong and sturdy fir what he is doing.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
wrong wood?
really needs bracing inside if they are not walmart subs
it probably sounds like ass because the port wall is flexing too
Ok thanks. He will send his box dimensions later today so I can see the port and box size too. I could hear some form of chuffing like air leaks but will verify on the check up day. And he says he doubts the box is braced at all, so it could be what you suggesting too
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Might be a good idea to start from scratch on the box.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yes that's a good plan lol. The dimensions are in 18H 34.5W 14D with a 16.5 x 2.2 port. This gives me a 3.2 cube box with 36sq inches of port and tuned around 34hz (11sq inches per cube). Port area looks kinda low for a slotted box with 2 12s.
Subs are re audio srx powered by a aq2200. Could the low port area be one of the issues
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
box flexing and not enough port area are two different things
what kind of subs are they?
They are re audio srx 12s. He has also confirmed no bracing inside.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
3.2 net is low imo 2 12s need 3.5-4.5.
36" if port sounds low to me as well. 1 12" with 20mm xmax can push that per to its limits.
No bracing is another no no.
Pull the subs add bracing test
Invert mount the subs test
... Make the port bigger... Somehow?
Build new with the results from above testing in mind.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yah I'll do so. These subs actually have 18mm of linear xmax. Which is around 35sq inches of port needed per sub lol. Making the port bigger might be the tricky 1 imo cause either way we need a port twice as big. We will start the tests tomorrow. But as you say a new enclosure is the best way out
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   0 Members, 0 Anonymous, 4888 Guests (See full list)
