Need help box build
Please post your max dimensions and the power you will be running
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Thanks but will that fit in the astra because I have see the box before and I'm not sure in I will get that 4 Inch clearance
The box is within the max dimensions you listed, take some measurements where the box is going, if you are still uncertain I can do a box with both subs and port firing up so that no clearance to the rear is needed.
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
