TezasBassBox Posted March 21, 2015 Report Posted March 21, 2015 Hey guys I'm trying to build a ported box for this sub using Torres. I'm trying to get the best sound for my daily driver. the re site says 1.25 cubic feet is optimum and 34hz is best. I'm trying to figure out the port area and anything else i will need to make this thing sound good. I currently I have a box I built using the re calculator and it sounds great but I feel there is more to be had here. and advice is appreciated. The dimensions I have to work with are 13 wide x 15 high x 25 deep this will be a console box between two seats in a ruck. Subwoofer Specifications Subwoofer Series SEX (RE Audio) Subwoofer Size 10" RMS Power Handling 600 watts Voice Coil(s) Dual Impedance (Per Voice Coil) 4 ohms Voice Coil Diameter 3" Sensitivity 83.2 dB Xmax (millimeters) 18 mm Subwoofer Design Round / Circle Main Cone Color Black Woofer Composition Dual Composite 2-Piece Cone Woofer Surround Rubatek Foam Magnet Structure Triple Stacked Subwoofer Grille No Re-Cone Kit Available No Recommended Enclosure Specifications Recommended Enclosure Type Ported / VentedSealed Minimum Sealed Box Volume 0.4 cubic feet Maximum Sealed Box Volume 0.65 cubic feet Minimum Ported Box Volume 1.0 cubic feet Maximum Ported Box Volume 1.25 cubic feet Top-Mount Depth 6-1/2" Cutout Diameter 9-1/4" Shallow Mount Installation No Electromechanical Parameters Free-Air Resonance (Fs) 26.6 Hz Equivalent Compliance (Vas) 31 liters Total Speaker Q Value (Qts) 0.42 Electrical Q Value (Qes) 0.46 Electrical Resistance of Voice Coil (Re) 2.8 ohms Mechanical Q Value (Qms) 4.4 Subs don't hit when powered by cheap amps!
Cj Kumz Posted March 21, 2015 Report Posted March 21, 2015 How much power are you running? And what are the specs of your current box. Your calculate the port area needed from www.carstereo.com/help/Articles.cfm?id=31 Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
TezasBassBox Posted March 21, 2015 Author Report Posted March 21, 2015 Im currently running a kicker zx pushing 500 watts. the current build is sub up port forward. 13.5in H x 14.5in W x 19.5 deep built off the RE calc. The next build will be sub down port down. I will need to cut the with down by 1.5 to add sides that will elevate the box off the floor 4 inches. The depth and height can go up if need be. preferably the depth though. Thanks for the response. Subs don't hit when powered by cheap amps!
TezasBassBox Posted March 21, 2015 Author Report Posted March 21, 2015 kicker zx750 Subs don't hit when powered by cheap amps!
TezasBassBox Posted March 21, 2015 Author Report Posted March 21, 2015 Im having trouble using the port area i get from the link on the Torres calc. i cant get the tuning below 100 Subs don't hit when powered by cheap amps!
TezasBassBox Posted March 21, 2015 Author Report Posted March 21, 2015 delete Subs don't hit when powered by cheap amps!
