beanbo12 Posted March 25, 2015 Report Posted March 25, 2015 I have one sundown sa15 d2. I have a rockford fosgate prime 750.1 powering it at one ohm. I also have 8" pvc(which can be made into a aero port or kept straight) on hand for the port or a slot would be fine. My max length wise is 36 and my depth and height is around 18 or 20. The help would be greatly appreciated. Thanks Ps.. 35 hrtz I guess to keep it at spec or whatever is best and the ride is a 2004 Ford escape.
beanbo12 Posted March 25, 2015 Author Report Posted March 25, 2015 Sorry forgot to mention I would like to get the deepest and most spl out of the box. And the height and depth can be accommodated for the best results. Thanks in advance
Joe X Posted March 25, 2015 Report Posted March 25, 2015 Here is a suggestion sub back / up port sideways, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
beanbo12 Posted March 26, 2015 Author Report Posted March 26, 2015 Thanks for the cast reply Joe x I appreciate it. Would facing the sub up and having the port straight up and partial exposed have any advantages.
Joe X Posted March 26, 2015 Report Posted March 26, 2015 You could have half the port out but I wouldn't see much of a point in doing an ugly box if it can be done nice, maybe with a slot port but yes it can be done and the sub up as well, in fact with the box I left you, you can do the sub up.
beanbo12 Posted March 26, 2015 Author Report Posted March 26, 2015 I will build the box you left it will be a nicer build. Does the portion of the subwoofer matter I see that it is a little on the right side, could I put it either right.
Joe X Posted March 26, 2015 Report Posted March 26, 2015 It's important that the inner end of the port stays away from the sub, it also important that the pipe is not right against the motor of the sub, this is why is placed the way it is, as long as those things are accounted form you can move it some to a position you like.
