FI50 Posted March 29, 2015 Report Posted March 29, 2015 Hello, Im trying to decide which setup to go with and if i even have enough space for two bls. First setup would be 1 15" fully loaded bl, sub up port back on the bottom in the center. Second box would be 2 fi BL fully loaded 15's, sub up, port back. The dimensions i have to work with are: Width-44.5" Depth- 18", max 19" Height- As low as possible but that doesnt matter too much. somewhere around 18-20" I guess maybe taller maybe shorter depending on the setup. Gonna be running 1 ct 1400.1d on the single bl. And on the 2 bls id be running 2 ct 1400.1s strapped. I listen to rap music and i love to hear the low notes, but also dont wanna completely cut out the highs. thanks, Mike 04 v8 explorer with a fully loaded 15" BL
FI50 Posted March 30, 2015 Author Report Posted March 30, 2015 bump 04 v8 explorer with a fully loaded 15" BL
FI50 Posted March 30, 2015 Author Report Posted March 30, 2015 Can sonebody please help me with a design? 04 v8 explorer with a fully loaded 15" BL
Joe X Posted March 30, 2015 Report Posted March 30, 2015 If you are doing this behind a 3rd row and you only have 19"D total it would be hard to do port back, on your dimensions would also be difficult to do the port across the bottom properly so here's a simpler alternative: NOTE: power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
FI50 Posted March 31, 2015 Author Report Posted March 31, 2015 thanks but i think im going with the 2 bls do i have enough space? im cool with going taller. 04 v8 explorer with a fully loaded 15" BL
